zacky6661
So I drove my truck around to do something for my job, and I started getting the running out of fuel symptom of the motor surging like its got twice the power (neither tanks fuel guage works -_-), so I quickly switched tanks, and it eventually smoothed out. Got back to work and it sat for about another 2 hours, which is usually how long I have to let it sit before it will start again (IP heat soak im leaning towards from research, havent had the money to swap fuel filters or return lines...).
Well this time it didnt start at all. Cranked, didn't even act like it wants to start. Now my assumption is the nearly running out of fuel is the root of all evil here, but it gets even better.
So I give it brief cranks to ensure my starter does not overheat, and bleed the schrader valve on the filter to get air out as I am doing so. I did this for about a half hour, still didnt even act like it wants to start. Then my batteries die, in the middle of a parking lot. Great.
So someone driving a nice new shiny cummins is kind enough to offer a jump. Nice guy, but I had to hear the usual Ford bashing. Yeah, his $40k dodge is going to be a bit healthier than my $900 dollar truck thats 3 times older than his. Anyway, nothing. Still wont even crank.
Multimeter out, both batteries test 12.58 volts, the draw while cranking isnt bad, and ALL cables test only 0.3 ohms.
So the batteries are charged, and the cables are good, but the engine cranks like the batteries are nearly dead now.
After letting it sit, no cranking attemps sitting that is, for about 20 minutes, I get under to check the starter and its hot to the touch.
Am I correct in assuming my starter has done one of two things, either heat soaked, or kicked the bucket?
I took the batteries out overnight, gonna take em in just to make sure theyre tested fine, then see if it will do anything, I just want opinions before I replace the starter.
