Dana 44 HD straight axle work?
lindstromjd
Black Sheep
West Des Moines, IA
Just curious... will a 1977 dana 44 HD (8 lug from a 1 ton) work in place of the TTB axle I've got right now on my '85 F250? I don't suppose it's a straight bolt-and-go kind of conversion?
freebird01
Post Turtle!
Fort Wayne, IN
they are different...the D44 will be 29 3/4" i believe and the TTB frame will be 34" to the center of the spring perches. and you cant just move the perches as the drivers side perch will be halfway up the side of the diff
D44 would work...but ...BUT...as Jason mentioned..you'd have a significant issue with spring perch widths being different.
FYI a D44 was NOT installed in an F350...they only came with D60, the D44 did however come in F250's
One Caveat for D44 is if it's a coil sprung model and you get the radius arms, you could....could take a coil sprung 2wd setup and install the D44 with that and swap some 8lug knuckles over....
Seriously though get a 60 and be done!
lindstromjd
Black Sheep
West Des Moines, IA
Thanks for the input and advice. Can't afford the Dana 60 though... That's the problem!! Lol. I'll probably pass on gettig and installing it though. And you were right about it being from an f250, AND its a 77.5 (if that matters). It is already an 8 lug axle though. I had some of my initial info wrong.
freebird01
Post Turtle!
Fort Wayne, IN
The f250 d44 will always be leaf spring.... the f150's and bronco d44's are coil spring and 5 lug..
The only ******* child is the d44 in the f150 supercabs. They were a 5 lug d44 with leaf springs
rockbender
Bend, OR
My E350 has a coil sprung D44HD. Of course it didn't exactly come from Ford that way. :D
Hardass559
89 7.3 banks turbo
falconer/new york/usa
if your handy with a welder you can move the perches and use round botem u bolts and rear spring plates and weld shock mounts on after that i put one in 84 f250 .you shuld figure out somekinda track bar tho you don't rely need it tho but i hily recomend it
Drew2010
Fulton, IL
keep shopping around for a D60, you'll be happier with the end product
X3^^^^^^
Having both axles right now, definitely go with the 60, keep saving those pennys, you will be so much happier in the end.
You will look at a 44 like its a toy after having a 60...
And I believe pre 1980 is 32" spring spacing and 1980 and up is 36"
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
The D44 is not an upgrade from the D50TTB. It has a lower weight rating, smaller bearings, and will be a challenge to adapt to the post '79 trucks. The D60 is a bolt in affair, pretty tough to beat any way you cut it.
