Cruiseomatic
Defining Insanity
After so long of using bad/old/salvage cables, wrong size, plain junk, even jumper cables!
And after almost a year now, I finally realized that you can't pull the same "just to get by" techniques on diesels as you can gassers.
So I decided to start spending more and using the right equipment to get this truck done. I really didn't want to sink alot just to get it started but I am..Hope I'm not wrong. Some of you may remember when I used jumpers to spin this engine over in a old YouTube video I made.
So, I bought a POS cable from oreilly's Yesterday. Just got it on about 30 minutes ago. When I was bolting it to the starter solenoid, It was almost ready then it happened....I SPUN THE DAMN THING! Thats right. I must of applied enough torque that I spun the solenoid connection....Being hopeful, I tried to crank anyway. Nope. Its dead. So now I have to go get it rebuilt...Not really a bad thing though. It was cranking slow to start with. For a while, I had a decent POS cable on it and a good ground. I know this because I had just taken a 1000CA motorcraft battery off the charger, quickly threw it on and hit it. Voltage was up around 15 or 16 according to VOM. Volt gauge on dash is a damn liar. I hit the key and it nearly spun out of the truck. Waited an hour and back to normal again.
Theres a video on here where someone did a compare of a bad starter to a good one. Can't find it now. Either way, I get the right crap and now I have to wait to get this one rebuilt..... And I just blew my 2 week budget. Now I have to wait until this Thursday to do anything.
At this rate, It'll be next year before it runs.
Moral of the story is, When Installing new cables on a 6.9/7.3 starter. Do it with the starter out of the truck and hold that plastic crap to keep from spinning it like a top.
What idiot came up with that design? " Hey, Lets use plastic to hold high amprage cables that are going to be in a very dirty environment and require lots of torque to keep good connection for max amp draw. Who cares if it breaks, Not our problem. And lets put it in a hard to reach place."
