dam door handles
sassyrel
iowa
are those the same handles that are used on a 96 passat?????
NJKen
is a daddy!
Central NJ
Those handles suck! Replacements are redily available since it is a common problem. The little hinge thingy inside wears out. I do no know if they are the same as the 96 or not.
Good Luck
Ken
sassyrel
iowa
well---the handles dont really wear out--the pivot pin comes out--take the door handle out--have to remove inside door card--after get handle out---youll see where the pin comes loose--push pin back in--then take half(approx) of a bike chain link--and youll see how to put it over the pin--and drill the area next to it with a 1/8 drill bit--and dont drill toooo deep----and use a 1/8 pop rivet to rivet that half over the pin--end of problem--and lowwww cost!!! hard to describe--easy to do--
placidoert
