HI,
So far so good on my D60 swap, it sits under the truck very well at the moment, but then ran into problems. My truck details are in my signature and the donor for the D60 swap was burnt down 1990 F350. Only problem so far occurred today with front driveshaft. I've got new double cardan joint shaft for 1990 F350 that i would like to install. So i just removed the output yoke and was about install new yoke to it, but then i noticed they're different . If you look at the attached picture, the one with 31 square splines was the one that i removed from my truck and that 32 v-groove splined was supposed to go in. That 32 spline yoke is Dana part# 2-4-5441 which i thought was the right for my application, but i guess i was wrong. So what's the correct Yoke i need to get the front driveshaft installed...
Thanks..
Click the pics for larger one
Yoke pic, right one was on truck and left is 2-4-5441:
Driveshaft mount to yoke
Thanks..
