I was told a recore of my OEM 94 idi 7.3 van radiator was going to run approx $195 -$395 avg. with the re-core shop saying it could more a little more or a little less, (no labor because I'd R&R) but tax @7% would be added, the variable in price to recore, depending on several factors they mentioned. I got the quote over the phone from a local radiator outfit, in business 40+ years. That was a BIG variable in price. I opted to do web research and to measure my current radiator and compare to F250-350's and my van was VERY close in core height x width x depth. So, I finally made my call Champion Cooling direct in California and got the new all aluminum radiator with a new 13lb. Radiator Cap for less than a recore, I think it came to $250 with shipping. The reason I did this is that I ALSO want to eventually re-core my original. I'll put it back in the same box the all aluminum new radiator came in when I do re-core it, then I'll put it in the rafters as a backup. Hope this helps, Dr. Charles.
Sent from my SM-T567V using Tapatalk
