cummins n ford
argve
Resident Fruitcake
Gwynneville, Indiana
Yer gonna need the computer to run the engine.
Having not done a swap before I can't tell ya all that you will need. Darrin Tosh swapped in an early 12v with the rotary pump into his brick nose ford. I helped with yanking the donor out but putting it back in I missed....
Do you have the 24 motor already? if not have you considered a 12 valve swap, all the 12v motors (first gen - rotary pump and second gen - p-pump - inline pump) only need one wire to effectively run. They are both mechanical injection motors so they are pretty simple to swap. Just make 'em fit....
1977fordf150
King, NC
24 valve
yeah i have a 24 valve and I have a 5 speed trans and I have the computer. A painless wiring harnest kit from painless wiring and a swap kit for the 24 valve from http://www.fordcummins.com .
RangerDanger
