TBigLug
I Miss U Baby Girl
Well, the old **** is giving me problems. Had to have a truck to haul horses to the tree farm this year to make my money so I ended up buying a 1993 Dodge D-250 off a buddy of mine with a 5.9 CTD and a 46RH. Don't much care for Dodge trucks but the price was right and the thing runs spectacularly. When it warms up come Spring I think I've decided to put the motor and tranny out of the ole Dodge into the ****. I've decided even though I'm a Chevy guy, I DEARLY love my old truck and feel I have to give it a fair shake at a new heart.
Got a couple questions for you "Outsiders" j/k that have committed the "Cummins in a Ford" sin...
Is the GP relay strong enough to habdle the intake heater of the Cummins? I'll be using just a manual push button that's already in the truck.
Can I reuse the Dodge's radiator? People say it's small but it's BRAND NEW.
Does it make more sense to reuse the Ford crossmember or use the one out of the Dodge?
What mods need to be done to the crossmember? Not sure how each trucks mounts work. I'm away from both at the moment.
Are there any firewall "massages" that need to be done to make it fit?
How does the Dodge 46RH speedometer cable/ sensor compare to the Ford C6's? Are they both cable? Will one cable work in the other tranny?
Any advice before I get started?
The plan is to pull out and sell the 6.9/ C6 out of the Ford. Pull the 5.9/ 46RH out of the Dodge. Use motor mounting kit from http://www.fordcummins.com/80-ford-12v-engine-mounting-kit.html to get it in there. I think I can reuse the yoke from the Dodge's driveshaft, cut down my driveshaft and get an offset U-joint to hook the Dodge yoke to the Ford shaft. Exhaust would just be a straight pipe. I would just take it in for a new pipe down from the turbo to my stock Ford exhaust.
It all sounds pretty simple on paper, just trying to preplan for some troubles down the road.
For grins, here's the ad from when my buddy was trying to sell the Dodge to give you an idea of what I'm working with. I won't tell you what I ACTUALLY paid for it. High miles but the tranny's been rebuilt before and the motor produces minimal blowby and has more than enough power.
http://lansing.craigslist.org/cto/2029138712.html
