Cruise switch problems
mbass777
every were USA
on my 93 zf5 speed the po installed a adjustable clutuch rod and because of this the cruise control will not work because the switch left hangging in the clutch depress start position so cancels the cruise now to my question is the cruise also canceled by the brake light switch and if so any one have a clutch switch diagram so I can figure out how to wire around the clutch switch and just let the brake switch cancel the cruise
Midwest_Mudder
Kennard, NE
should only be an open/close switch. thats what it looks like in the wiring diagrams. you could try unplugging it, BUT then you'll need a push button somewhere to activate the safety feature so you can start it.
to answer your question, yes, the brake switch also shuts off cruise
cdnf250
maple ridge, b.c.
Just go to a wrecking yard and find an automatic truck and get the small plug that is on the end of the same wiring harness and plug it into yours. That way it works just like an auto. one does. It will allow the brake cancel to work and bypass the clutch start up neutral switch.
Lance
