Josh Carmack
I bought two 1990 7.3's in the same week about a month or so. I was tired of gasser problems and wanted to go the diesel route for more than one reason. I grew up on a farm, around tons of diesel engines, and then we quit farming so I spent most of my mechanic years on gassers. I know most of the big stuff to know about diesels, but the details are what get me. So i'll pose this question for people that have more 7.3 IDI experience. My big truck was running and cranking perfectly when I purchased it last month. I have put a couple thousand miles on it, and it has ran and started perfectly til last Thursday. The original owner stated he believed one glow plug was bad when he sold it to me as he was noticing the Wait to start light would extinguish faster than normal. It was still starting fine in less than 5 seconds of cranking even on a 20 degree night. Last WED I got in it in the evening after work and noticed the WTS light went out very quickly and it was a PITA to start. The next morning it started better but not as good, the next evening after work it took about 30 seconds to crank. Friday morning it would not start at all even after enough cranking to make the starter sweat and scream at me. One little half second shot of either fired it right off, and it has taken ether pretty much ever since. This morning and afternoon it required ether to get it running. My question being, this truck sounded hot from the very beginning, it had been some many years since I had been around any IDI fords, but it seemed louder than most. Then I recently read that advanced timing cam burn out GP's and cause loud idling. I checked yesterday and found three bad GP's on one bank and quit looking because I knew that was enough to make the controller not light the rest.
My questions are, is it normal for several glow plugs to go out in a short two or three day period, as mine seemed to do in less than a week. It went from starting good to not at all almost.
And can advanced timing burn them out quickly, or does it take a long period of time. In other words, can advanced timing burn out plugs in a very short time, say a few months, or does it just shorten their lives by say 10 to 20 percent. The original owner stated the I.P. was only a year or so old. SO there was the opportunity for the truck to get out of time. The truck is a 1990 f-350 Crew cab long bed with 350,000 miles. Truck still runs fine and has plenty of power and starts great after the first start, it is only a problem to start once the engine has cooled. Hot starts are sub one second cranking times.
