Ask and you shall receive:
This is the first side detail; Here you will note it is flush with the side of the radiator, and the two upper pins (if you get one you'll see what I mean) are broken off.. mine was nicely done for me via a van / deer accident.
This picture shows the top down relationship of the fans and the front of the engine.
This is the electric controller setup... the module on the far right is the temp control module.. I got it from Autozone for I want to say $35... however, the two fans combined startup amperage draw is around 60-70 amps, and it popped the small 30 amp fuse, so the relay on the controller turns on the two left relays, and each relay runs one fan motor to ease the max draw across each. Each relay is a 40 amp max relay, and the fans run ~15 amps each under full speed.
This one shows the piece of 4" flat stock used to anchor the fans to the existing radiator shroud mounting holes. Crude? Yes. Is it going to break, or weaken? Not in this truck's lifetime. An afterthought (of now 4 years) is I should have painted them...
Another side profile showing the alternator, upper radiator hose, and such. Maybe I should have used a different color than green wire.
This one shows the lower end of the fans ass'y and the top of the crank pulley to show the relationship of depth. The bottom of the fans are about 2.5 - 3" below the top of the crank pulley.
This on is just a picture of a straight up angle from under the the engine bay.
As for durability / reliability, I have the temperature of the probe set so that when the upper corner by the upper hose reaches about 190 they turn on... and when I'm pulling my 7,000 goose-neck horse trailer, they run constantly (as was my intent) and she doesn't run hot. She runs cooler than with the mechanical fan. I've not had any issues with the motors as of yet. Also the nice things with these bad boys is they cool the truck off much faster when idling than the mechanical fan does. These were designed to cool the venture with a 3.4L V6 but I would say, other than pulling in 95+ weather, with the A/C on, going up a long hill, with my trailer loaded to the gills, they keep up.
Hope this helps some...
