cranknrods
thought you guys would like this. the guy in this thread got his sg. down to .85. #2 is .84 sg. (sg= fluid thickness). he mixed 33% k-1 and 66%wmo.
came out to the viscocity of #2 diesel.
.01 difference isnt enough to worry about
but for each batch of wmo you get the sg will be different because of the different weights of oils in that barrel.
im thinking that if i get my sg. down to the same as diesel,
and then use a centrifuge to clean it untill it starts turning dark brown instead of black
then make sure it doesnt have any water in it
my cr cummins wont even know the difference except for the different combustion characteristics. (probably slight difference anyhow, after adding that much k-1)
then run some water injection to help with the coking and its all good
maybe even add some 2 stroke oil to make up for the k-1
so any how... i thought it was a good read
http://www.thedieselstop.com/forums/f22/wmo-info-201451/
