codes
camo85
smoke em out
Lewisburg, PA
I'll dig up my codes list tomorrow and get back to you with them. I'll post it on here too, but will probably just call you with them when I find it. I know the list I have has those type of #'s on it, the link Russ put up doesn't have the same examples as my scanner pulled.
Aaron
camo85
smoke em out
Lewisburg, PA
p0a06 = motor electronics coolant pump ctrl circ low
p1165 looks to be around the numbers for fuel and throttle errors
p09fe I can not seem to find anything
I will explore a little more when I get some more time, I'm having trouble opening a few web pages that look like they would have all the codes. There are so many codes for the OBDII system that it is hard to find all them on one web page.
Aaron
aaklingler
Winfield, PA
Thanks for the help, I haven't been able to find any on any of them. I'm not quite sure what that means. You didn't happen to look and see how many rpm it was turning while cranking.
camo85
smoke em out
Lewisburg, PA
No I didn't take notice. These three codes were from your white truck though weren't they?! I'll post a link if I find anther good codes site. The one I found the one code on was http://www.scribd.com/doc/19441519/ford-dtc , I know I have another one printed out that is posed to be a complete list but I can't find it rite now.
Cv axle
