Clutch Problem
92F350CC
Ford Man
Las Vegas
In the F-350 described in my sig, when i start the truck up, sometimes it won't go into first or reverse unless you shut the engine off. Also the clutch has to be pulled back up with your foot every time you use it(probably just a bad spring, how hard is it to get to that?). Any suggestions are heavily appreciated. I don't want the clutch to go out and leave me sitting on the side of the road.
Mike
Stroker
Cora
Check the firewall out where the linkage penetrates, it might be cracked and flexing not allowing full clutch engagment.
Nanohawk
