Clutch pedal linkage ?
SIKPUP
Spring City, Pa
Ok, I've read the IDI tech article on the clutch pedal linkage rod end fix, But now my 93 has the plastic rod with the broken end -cuss :mad: -cuss Now, is there a fix for that ? or do I have to buy a new clutch m/c ?
Does the rod pull out of the m/c ? I hate when I can't use my truck because of Fords stupid plastic pieces. :puke:
I need an easy fix :rotflmao I have more time in Jan.
Thanks,
Mike
wwwabbit
Mmmmm Diesel
Sooke, B.C. Canada
Can you put one of those joints over the plastic rod? If there is enough there for it you should be able to. I know I am loving mine with the real rod end on it.
SIKPUP
Spring City, Pa
Here's what I found out by takeing it apart, the m/c end of the rod is metal with a smaller diameter, and the pedal end is plastic with a little bigger diameter so that it will push the start saftey switch, ( clutch needs to be pushed in to start ) So the rod end trick won't work without rewiring the switch. I Don't want to do that !
I'll let everyone know how it works out.
Mike
Cv axle
