RavenTBK
Seriously Ford? Who in the holy hell thought it was a great idea to use roll pins to retain the stupid hose between the master and slave. This now ranks as the stupidest thing I have ever run into on repairing any of the family cars. Even beyond the random torx bit on front calipers that GM used for 3 years that no parts store carries the bit for and had to special order off the interweb.
In my case, apparently the slave has been replaced recently. The roll pin was rather easy to remove, and split the tube from the cylinder. The master, on the other hand, has been a complete pain in my junk. Beyond the contortions required to unbolt the thing, beyond one of the studs backing out of the master cylinder instead of the nut coming free, I get to the stupid roll pin. Its halfway out, and flat out refuses to go any further. I have broken two punches with the stupid cylinder moving every time I strike it, not to mention the numerous times I have ended up striking my thumb or finger.
I've already soaked it with PB, and am able to easily drive it back to its original spot and back again to where it stops.
Any tips to getting it free? Where can I wedge the master that it'll hold steady enough to drive the pin? I am almost pissed enough to cut the tube.
