gonecrazyi
When I crimped my last set of battery cables for my idi I used a bolt cutter. Worked perfectly and has held up just fine for the last year or so.
Go to this website and make your own with their supplies, a vice on a bench and a cheap propane torch from your local hardware store. We used them to wire up our trailer last year, makes it easy to order for newbs like us.
It is really easy to make your own that way if you have a helper. They have the flux and little pellets to size of solder to put into the lugs and heat up. You can get some shrink after that to tighten up the joints. You can even get some cheap conduit from them to keep all your runs safer.
We redid our clunker a couple months ago because we got some free wire, but from the replacements I have seen that place can save you money.
We also put those marine style lugs on so you can just take the wingnut on/off with ease and connect new stuff later, and every wire is seperate. Just make sure the size you get corresponds to the posts on your battery and the bolts match up to the lugs you pick, etc.
And if you don't feel comfortable with making your own, they will make your runs for a small fee and ship them to you.
Depending on your starter though, you might need a custom lug on that end depending on the angle. We had to make a 90 with ours so the big ass wire would come off straight into its run besides the engine and up to the battery.
You know what after watching this video http://www.youtube.com/watch?v=SXDkNMDDrBs&NR=1 I think I am going to solder. I have a MAPP torch but nothing to crimp with (well 22-8 AWG but not 2/0). That cable was expensive enough without shelling out 50-200 bucks for a new tool ill only use once in a blue moon. Can I use regular old paste flux like the kind I used for sweating copper pipe?
That wire AWG 12, comes off the relay mounted on the fender, the ring terminals, relay end a 1/4" bolt hole, starter end #10 bolt hole. Just wire tie to the battery cable a few times.Also how do I attach the smaller wire that goes to the solenoid?
