Cleaning out
FarmerFrank
Blairsville, Pa
Clearing out most of my IDI inventory.
You name it, I probably have it. 6.9 and 7.3 injector lines, water pumps, oil pumps, probably a spare or three IP's, accessory brackets. If you need some little part let me know.
I also have:
6.9 head studs ran 500 miles
Factory turbo kit with banks down pipe
Factory turbo block and internals
FarmerFrank
Blairsville, Pa
Can ya give me measurements of the driveshaft? No brick nose pedals on the shelf
FarmerFrank
Blairsville, Pa
just did a quick count at one area of parts:
2 crank shafts
4 oil pumps with pickups
16 rods
2 sets of valve covers
2 timing gear covers
3 good used water pumps
5 complete sets of injection lines
7 core injection pumps
2 good injection pumps (one with about 6000 on a rebuild and fuel turned up)
3 sets of motor mounts
3 sets of diesel motor perches for the frame
1 heavy 6.9 flex plate
1 turbo flex plate
Couple sets of pulleys
1 6.9 air snorkel that goes beside the radiator
1, maybe 2 air filter housing
That's all I can see right now....
Make me an offer on anything
FarmerFrank
Blairsville, Pa
1 Delphi lift pump with less than 500 miles on it
2 crank shafts
frame
1 turbo flex plate
Make me an offer
austin92
Brazil. IN
Price depending, I'd have interest in the turbo, studs, and a core pump. Do you have OBS a-pillar trim pieces?
FarmerFrank
Blairsville, Pa
I got red and gray. I'd have to look to see if any mounting tabs are broken or not
theSHERPA
Austin, TX
Do you still have a tilt steering column? Crawled out of the cave and sent you a PM
Sent from my iPad using Tapatalk
Zaggnutt
PA
Oh man! I just came back to Oilburners for a minute to see if you wanted a set of heads back for cores! What's goin' on Frank?
FarmerFrank
Blairsville, Pa
Honestly Rich I'm not in any need for them, but I do know one guy that is looking. What condition are they in?
Zaggnutt
PA
One is in very good condition. Has 180k on it, but underneath the valve covers it looks beautiful. The other one needs rebuilt with new valves and guides. You gettin' outta the IDI adventure?
SixFourShanks08
