06cumminspower
ok, so I have been trying to get this 01 back together and got it cranked but only running on passenger side so I unplug oil rail and is shooting out and then crack fuel line running from filter into driverside head and is getting plenty of fuel. however I was curious about the fitting inbetween line and head and removed it and I can not blow through it nor does it look wet underneath it. so should I be able to blow through it with ease with my mouth? ford wants nearly 80 bucks for this and looked at the obs heads I had lying around and they seem to be a straight through fitting with out a check valve so my next question is; is it even neccesarry for this check valve or can I just use a regular fitting? I have took the tiny snap ring out and tried cleaning it up but still near impossible to blow through ( I did get shop air to go through it and then could blow with ease in either direction but now its hard again?)
