Really not sure what these rubber mounts do for the radiator anyway. We have the 4 bolts to hold the radiators to the core support so. Why is the radiator on these rubber supports anyway???
Yeah, to be honest I don't even know what rubber isolators they're talking about. LolReally not sure what these rubber mounts do for the radiator anyway. We have the 4 bolts to hold the radiators to the core support so. Why is the radiator on these rubber supports anyway???
Rubber mounts, I ran into the same problem when I ordered the champion radiator. Sadly I had destroyed the old rubber mounts trying to get them out. Went to a wrecking yard and was able to get a another set out after learning how NOT to do it on my dead radiator. You can have them if you need them.
Because I ended up returning my champion which was damaged shipping too. I did try using it, but one I hated how hot it got things under the hood. And two it leaked within a couple days of install (likely from the obvious drop damage to it).
I ended up buying a brand new copper and brass radiator from a place here in Washington which makes them. Nearly identical to OEM, it was $538. And it came with new rubber mounts! I can try to dig up how to order if you like. Can't order direct, had to go through a local shop.
For the questions on "what mounts", they're between 1/2 and 3/4 the way down on each side of the radiator. As others have said it helps with the vibration from the engine.
