Matt_INW
Hey look there's green stuff on the ground.
Yeah, got to Home Depot this weekend and smelled coolant. The truck was up to operating temperature, and around 70 degrees outside. The leak is coming from where the top reservoir connects with the core. The shop I called said they could look at it but expected it would need to be replaced due to age alone. So, apparently I'll be replacing the radiator as I'm not sure it's worth the expense to repair (if it can be repaired) as it's 24 years old.
In perusing the forum, checking NAPA, and Ford Parts, I'm leaning towards Champion Radiators. A new one from NAPA is ~$300 more and from Ford is ~$700 more. From what I've seen it's well made. Anyone hear of or have a bad experience with Champion? Or strongly recommend another brand, even the $1,000 for Ford (ouch)?
And while the radiator is replaced, I'll be doing everything else (water pump, thermostat, fan clutch, hoses).
