Since the Facet is the hot new item is anyone still using the Carter p4070? Has a couple things I find beneficial, over double the flow and 1/4 inch pipe fittings so 1/2 inch hose can be used with a sump. Anyone still having good luck?
33gph just seems low to me, they are designed to feed a small engine, im sure they work fine and are sufficient for a stock application, but I like fuel.
I kinda figure there's enough fuel for cooling...Its not just ho much fuel you use, there has to be plenty of excess for cooling the fuel system.
Edit: I could use a lot of fuel flat out for an hour, as long as she didnt melt down
The flow was just a theoretical, it should suffice for most applications. But I want to have enough on the dyno just in case.Don't get me wrong...Carter is good...but that Facet is a true work horse built for longevity of life!
This is probably an accurate statement, but the was a Carter pump sitting on the shelf at work, so its going on in about an hourI bet if you have two electric pumps, and swap lines between them and dyno runs without getting off dyno...you'll find little to zero differences between those runs.....
