payableondeath6
Impressively Ugly
I've just got a quick couple questions regarding the carrier (driveshaft support) bearing replacement I just found out last night I'm going to have to do
I see a couple different bearing diameters listed on RockAuto.com (although I'll likely be calling AutoZone, Advanced, NAPA, Carquest, etc...whoever has one in stock). Aside from the obvious measuring it, anyone know what diameter I need?
Another question. I soaked the bolts in PB Blaster last night and plan on doing the same everyday until I get to the job (probably Friday, and don't worry it's not my DD), but with the level of rust this truck exudes I'm sure they will prove to be difficult. Would a small MAPP bottle torch help any in getting the bolts out or getting the bearing off the driveshaft? Didn't know if it'd be worth dropping $20 to have one on hand before I start the job.
Anybody with a similar truck. Looks like the front shaft just bolts to the output shaft of the tranny and the rear shaft slides into the pumpkin...Is this right? Are the two pieces just slid together too?
Thanks for all the answers. Tried searching first and came up with some good stuff.
