Can't get injection pump out
Fordfan90
Idaho
i can't get the injection pump out of my 7.3 idi. I don't understand why it's not coming out. Any help would be great appreciated.
Fordfan90
Idaho
I took off the pump nuts and the 12pt bolts and got all the injector lines loose but it won't come off. There is a gasket seal that looks to be on the pump where it's bolts up to the timing cover.
bbjordan
Snow Monkey
Ashern Manitoba
I think there is an o-ring on the snout of the pump. If it looks like there's a gasket between the pump and the timing cover, maybe some "clever" person put some silicone there. You may have to gently pry it away from the timing cover.
hesutton
The Anti-Anderson
Bowling Green, KY
Is the pump stuck to the drive gear cover? Or, are you having a hard time wiggling it out and off the top of the engine?
Heath
BFH, a rubber one, smack it on the side towards the gear housing on the square for turning it.
gandalf
Senior Member
CA &/or Maine
Now that you have all the nuts and bolts off, and the injector lines loose it should come out without too much difficulty. Are you able to rotate it, even just a little bit, as it sits there? You say there is a visible gasket seal between the IP and the gear tower? I don't recall that there is one visible. Can you send a real good picture of that?
Fordfan90
Idaho
Ya I can once I get off work and no I can't turn it or anything. I also have a question about the return line caps which kind does a 1990 suppose to have on it or does it not matter?
hesutton
The Anti-Anderson
Bowling Green, KY
Sounds like someone used silicone or something they weren't supposed to on it.
90 should have the larger 7.3 caps/lines.
Heath
Fordfan90
Idaho
So like these caps or the other style of them?
My guess is someone foolishly used RTV and maybe a gasket to "seal up an oil leak". If the pump will not turn from right to left then you have some sealant causing this. ALL these pumps have an oil ring that seals off the oil from leaking and.... That o ring allows you to adjust the pump for timing. This is a new one for me. Would never have thought any body would glue in an injection pump.
As for correct return line kits just look at the color of the clamps. Red is the larger lines and green is the smaller lines. DO NOT MIX & MATCH these line sizes. You will cause many leaks.
Fordfan90
Idaho
Okay thank you does it matter about the caps that you put on the injectors? Mine didn't have the ones in that picture so I don't know what kind of caps it needs
hesutton
The Anti-Anderson
Bowling Green, KY
What does it have on the injectors????
Pictures please.
Heath
lewisstevey7
