Can a bad CDR cause white smoke?
timothyr1014
chandler. az
I get light white smoke during acceleration and while high speed cruising...this mainly occurs between 1200 & 2400 RPM...the CDR is questionable.
Could there be any other cause?
dyoung14
Is getting worn out
spencer,tn
mostly in diesels when they burn oil it wont burn it blue, it will burn it black, cause a diesel will run on any oily substance
forcefed
Newark, OH
when is the last time you have checked your timing. Or maybe couple injectors popping too soon.
timothyr1014
chandler. az
i am thinking injectors is also a possibility....there is a deffinate miss as well that has started
it could be light grey
Injectors are most likely, especially if the exhaust really burns your eyes. If it is coolant causing it, you'd smell it.
