The engine in my truck I believe is completely stock. The only thing that I can see that is upgraded is that the down pipe is not crushed, and it has a 3" straight piped exhaust. I cannot tell from under the truck if the down pipe is 2.5 or 3", but it looks to be the same as the rest of the exhaust. It has the factory turbo with Garrett and AR .70 cast into the compressor housing.
I have a timing meter and have the engine at 8.6 degrees pulse BTDC, and have been looking for an affordable dyno somewhere around the greater Salt Lake City area. Gillette Diesel Service has a dyno and charges $75 for two pulls as a service for Before / After testing to go along with their installing performance upgrades. Or you can rent the Dyno for $150 per hour to tune your truck on the dyno. There are several other shops in the area, including one I found that looks to be just down the street from where I work that has a mobile dyno.
I just purchased a used 7.3l IDI camshaft which should be here in a couple of days. I will be shipping that off to Russ to be re-ground, hopefully some time next week. Once I get that back, I will have the cam already in my truck plus the re-ground cam. The plan is to be able to do a before dyno run at several different timing settings, do an in the truck camshaft swap, then go do an after dyno run at the same timing settings as the before runs within a few days of the first. I also plan on doing compression tests both before and after with the new cam to see if there are any changes there. I want to get all of this information for my own use, and as a baseline for future upgrades I plan on doing to the truck. I am hoping to be able to complete this some time next month, and will post the results once I get it done.
However, before I do all of that, I REALLY need to get a boost gauge and a pyro installed, and I really feel that it is important to know those readings during the dyno runs. I am pretty sure that I can install the boost gauge, but I have no idea how I would install a pyro, and would hate to pay a fortune for a shop to do it. I guess I know what I need to get done this month.
John Z
John Z
