cam talk, how do they run?
FarmerFrank
Blairsville, Pa
Lets talk dirty about camshafts... So from my understandings the R&D cam is more of a "screamer" cam where as the Typ4 cam is more of a towing "grunt" cam. correct?
I'd love to hear from people running them. Im rebuilding a 7.3 and have a Hypermax kit to put on it so nows the perfect time for a cam
bookite03
Nice Crummy
Oregon
Curious as well...keeping an eye on this thread.
I'm leaning towards a "torque cam" for my 6.9. Right now with the ZF/GV combo the engine is barely turning, makes the egt's climb unless I drop a gear. I turn 1500@55mph and 1750 at 65mph...and thats with 4.10's. A bit too slow for the stock cam/powerband I'm thinking.
racer30
western Oregon
With that low of rpm you don't have the air flow for a lot of fuel that's why it has High EGT's. But I bet you get pretty nice mileage if you stay out of it on the flat... I'm Running a J2 cam in my Motor Home... 86 Vogue Cosmopolitan. Now Turbo 7.3 IDI Powered. J2 cam, 910 springs, port work, lightened rods, .030 cut ceramic coated pistons, balanced, 90cc DB2, HX40w Turbo on custom up pipe's, 3" 06 Dodge intercooler, 4" straight piped, 4 speed Allison. 18psi Boost. It pulls real nice for a 21,000lb. Rolling ****....LOL... (That's my wife's nick name for the MH) Check out my flickr page. http://www.flickr.com/photos/racer30/
FarmerFrank
Blairsville, Pa
My thoughts were leaning more toward the rpm power because my NA doesn't lug well and I have to keep it wound out when towing
FarmerFrank
Blairsville, Pa
I've seen the pictures but that's more work than my 7.3 is getting! New baby cut my truck budget tremendously
racer30
western Oregon
Ya Your 6.9 will like the Typ4 cam. That's the engine it was ground to help...NA IDI...Build a Cold air pipe for it too...
bookite03
Nice Crummy
Oregon
We've got our first due in about a month...I've gotta double-time my projects before its too late lol
I agree with the lack of airflow, the cam seems like the next logical step for me. As for mileage, I've yet to go on a long highway trip. However, a few short runs on the flat land have put it in the 20mpg range. Not bad for a heavy lifted brick that's 27 years oold...at least in my book.
FarmerFrank
Blairsville, Pa
Actually it was getting married that hurt the truck budget the hardest, the baby slapped it again. Oh well, not complaining....too much.
Thats not bad even in 1 year old trucks!
turbo elk
Vancouver, Wa.
I'm interested in how much boost you can get with the new cams in a 7.3
With stock head bolts.
Nrliftedranger
North Royalton Ohio
i bought a rd cam injectors and pump ill let you guys know in a few weeks how it runs..... illl say this justin is a freat guy to deal with
The typ4 cam was designed for the logging community na engines but it works very well on any idi turbo or not. Now could the grinder make one for just the turbo idi.. Maybe but I feel they would have done that already if they felt it was going to be any need for it. these engines run fine with the standard rpm. Adding a cam that spins them faster is a rick I'm not willing to take. the pistons and rods are heavy. they are nothing like a sbc that will spin 8000 rpm all day long. Justin has a product to sell at R&D that seems to me to be dependant on his package of intake, turbo and pump. Breaking up that set is not what I feel is the right combo. The engineering that went into the engine design is far more than we know. Usually changing any part of it like the pump will increase hp but it decreases mileage. Thats not true with the Moose Pump line of products. Many have proven that time and time again.
gonecrazyi
florida
I traded my type 4 cam to my brother. Its in a crew cab f350 dually 4x4 10 inches of lift and 38 military tires. The truck has no problem roasting the tires in second and he regularly hauled 10 round bales and 5000lbs of feed like it wasn't there.
But hws having lifter problems now and were not sure why yet. Still runs good. Just smokes and knocks bad.
When I finally got around to finishing mine up, I've realized that my fuel system is DEFINATELY not up to par. I can't tell a big difference on mine. I'm going to start fixing that part when it starts to warm back up. I'm sure I'll be as happy with my Typ4 cam as others I've read about. Oh well, it was a $400 truck. You get what you pay for. One thing at a time!
