ameristar1
The One Blue Thing
Justin, the timing of the cam and the specs are what makes the engine work. The heads controll the power of the engine. As much air as you can get through the heads, that is where the power comes from. Now, the cam is the heart of the engine. It opens and closes in reference to where the piston is in the cyl. (BTDC) and opens a certain height (lift) and stays open for a certain amount (duration). That is for the intake. The exhaust uses timing of the valve for a partial scavenge effect. You can effectively move more air into the cyl. if there is overlap between the exhaust and intake. This allows the exhaust to be evacuating the cyl. until there is negative pressure and the intake will open. It pulls air from the intake in. Now, the more overlap you have, the engine will want higher revs to run within the power band. There is a TON more to it than that...but that should get you close.
Ameristar, do you sell cams too?
SWS
Not yet, just know a person or two that can get the job done. I may do like Agnem and put together a line of 2 or 3 grinds for the IDI's with the guy I work with and market them. There's a need for this. Once I find a source for fresh cores, I could do it. Regrinds wouldn't be a problem, it's just that with the reduced base circle, depending on how far you go with it, you'll need to get custom pushrods to preserve the geometry in the valve train.
You guys tell me what you want your motors to do and we'll work it out.
