reklund
My truck is in the body shop currently, getting the hood, cowl, and roof repainted as well as a small section of rust on the cab corner repaired. I took all the trim off before I sent it over, including the clearance lights.
A couple of the gaskets on the factory lights tore during removal- any idea if those gaskets are available separately from the entire light?
Is there an aftermarket light that shares the hole spacing that will be a direct replacement? I was hoping for some of those Recon LED lights, but I'm not sure if they'll install using the existing wiring and screws- I don't want to drill any new holes in the roof.
Also, what is the best way to re-install the cowl without scratching it? Should I have the hood removed? I had to remove the cowl to remove the washer squirters and the radio antenna- and I don't want do damage it during replacement.
Ryan
Ryan
