mariner45
Hi Guys,
I have tried using the search function but haven't had any luck.
I am wondering about re-running the steel oil lines for the C6 in hydraulic hose.
Has anyone done this ? Is it a good or bad idea ?
Reason I ask is I have had some problems with chafing through of the original steel line and had to replace using brake line material. Couldn't make a complete new one and had to use flared fittings to joing the pieces. They, of course, are now leaking and I am wondering about replacing both lines using a good quality hydraulic hose, appropriately sized, to replace with. This would cut down on vibration problems, access and routing the lines and of course rusting out. That would be from the C6 tranny through to the radiator cooler connections.
Has anyone tried this - if so how did it work out.
Anyone know the fitting sizes and types for the two connections (in and out) of the tranny fluid at the C6 housing?
As always. any comments welcome - how else do you learn. Any other idea's ?
Thanks
mariner
Thanks
mariner
