1983idi
So i am trying to get everything together for my swap before i start. I have the clutch pedal already installed. I have the transmission, clutch, flywheel and slave/master cylinders from an 89 idi. The master cylinder doesn't look like it will fit so do i just need to make it fit or is there a different one i need to get. Also if i have to use a different master can i use the same slave?
