Burning WMO, will 1 pint of brake fluid contaminate 20 gallons
That's the equivelent of $100 worth of diesel fuel. If it eats something, there is a good chance that $100 will cover it. Sadly, we are getting down to basic economics here. 2 years ago, I'd have told you to drain it and burn it in your oil furnace. :rolleyes:
jrou111
Mobile, AL
I was burning some WMO that I suspect had a small amout of brake fluid in it. Other than a prematurely clogged filter it ran fine.
If you burned 5 gal, then topped off the tank, and repeated for a bit it would dilute a pint of brake fluid to practically nothing.
4x4TruckinGirl
"Cowgirl"
Dixon, MO
This is sad, but it's the truth.... yet another reason to just run it......
subway
be nice to the admin :D
York PA
i cant tell you it wont do anything but personally i would run it. you are already deluted to a fraction of what it was.
so does anybody know what the real differance is between hydraulic fluid that burns lovely and brake fluid that is the devil?????
69dieselfreak
well that nice
rimrock arizona
dont quote me on this statement im not really shure
from my understanding that hydraulic oil is basically 15-40 ive put 15-40 in the hydraulic systems in old ford tractors like the 8n
but like i said im not really shure
cleithau
Northern Michigan
Burn it, that seems like the best plan. Did a little bit of research this morning and brake fluid will not eat EPDM rubber which is what most of the parts on a truck are. It will eat old natural rubber and oddly viton rubber but not the EPDM with is what most all average grade fuel line it.
cleithau
Northern Michigan
I did some research and DOT 3 is made of various types of Ethers and Glycols, its the Ethers that can eat some rubber, I think.
Supposedly it eats paint. I figure most of us don't want acid in our fuel. :dunno
yARIC008
Drives really slow
Orlando, FL
The solution to polution is dilution but.... When I worked in a chemical refinery we could keep sulfuric acid in a steel tank just as long as it was 99%. Its when the acid is diluted that it will eat steel. It will eat stainless steel when its around 3% in water. I saw it happen once. We ended up using a metal pipe called Carpenter 20. It made stainless look like cheap overseas steel. Sure would be a bummer if it ate every rubber part of your fuel system and injection pump but give it a try and let us know..:dunno
http://en.wikipedia.org/wiki/Alloy_20
MIDNIGHT RIDER
Midnight rider our idi rigs are trash pumps that can burn alot of stuff.
I know; I personally put some over half-a-million miles on my old 6.9, and countless miles on several others, both 7.3 and 6.9, back in the days when Ford offered the only genuine diesel truck.
TLBREWER
Windy B Ranch
Moriarty, New Mexico
I work with 96% sulfuric every day. I should have thought of this before. For everyone running different blends of fuels. All of our plumbing is PFA, or, perfluoroalkoxy or some such crap:rotflmao . It is virtually impervious to all chemicals except those with TMAH (tetramethylammoniumhydroxide) in them. All connections are flare fittings which you can do with a heat gun and it comes in everything from 1/4" up to ?. The biggest we use is 1 1/2". There is a pretty comprehensive array of fittings for it as well. It is also somewaht opaque so you can see through it. The down side is it can't be exposed to high heat and it is VERY expensive. http://www.entegrisfluidhandling.com/Default.asp?ln=en
Also http://www.zeusinc.com/pfa.asp
Tom
2manydsls
Bodfish, Ca.
I've used brake fluid to seal tubless tires where the bead doesn't want to seal. I just brush a little on the bead before mounting the tire. Works good.
Ross
