Well darnit! After hacking and rebuilding my new Y Pipe (which was a little deformed) I thought I'd be good to go with no more exhaust leakage.
WRONG!
The back two exhaust manifold gaskets on the passenger side are leaking.........
So my questions are:
- Is there a better (read: stronger) brand of gasket I can pick up quickly to replace these bad ones?
- How long do you think just replacing the passenger side gaskets will take start to finish? Naturally I leave in a few days for a hunting trip. I"m already pressed for time as is, now I gotta figure out when I can find time to fix this debacle!!
- Is there a loosen and tighten sequence I need to follow here? IIRC, torque spec is 35 lbs, correct?
WORST CASE scenario - lets say I flat out cant find time to fix this prior to the trip. Besides losing boost, and an annoying exhaust squeel (that also leaks a little soot on my firewall) am I potentially damaging anything if I don't get to it until after this trip?
WRONG!
