Freight_Train
Traitor to the brotherhood
Last weekend we cooked our Race car engine.2.5L with a 2.3L pan and gasket.The rear section pinched inside the pan when we were installing it and didn't get noticed.Blew all teh oil out the back and burned the bearings out.So,today we decided to pull the engine out of the Super Ford.The Super Ford is a 1988 Ford ranger 2.3L with 300K plus on it.The engine is a used replacement that was installed about 200K ago.Unknown miles on the engine when installed.To paint a picture here......Truck caught more air than a 747,Had oil put in the radiator by accident(Don't ask me...don't know how you could misstaken the Radiator for the engine...)Redlined constantly,had so many people in the bed once the bumper was dragging,(Got truck at 14YO,at 18 he wanted it dead so he could get help to get another vehicle.He was 26 when he sold it to me!!!)The truck never had its oil changed....would leak out so fast that the PO would just re fill it every month or so.There is not a straight body pannel anywhere.The bed is held on by one bolt,the tranny has burned out bearings,the exhaust fell off after the Cat.Ok,back to the engine.We pulled it out today.Spent an hour pressure washing it.When we got it on a stand and pulled all the junk off(Intake,Exhaust,Valve cover) we found a Roller Double D port Head.....Hmmmm,I think I just came out way ahead on my $100 purchase price of this truck(Which was running ok for a TOTALLY thrashed truck!).Cylinder walls looked dang near perfect.Went to pull the pan(funky Cast aluminum jobber!) and noticed that there were 5 or 6 broke bolts on one side(only 3 holding it on) and about 4 on the other side broken.....hmmm,not good.Drop the pan and first thing I see are 2 large chunks of something......OH crap....Pick it up and it is aluminum about the size of a quarter each.....Look inside and see the skirt is missing on one piston.....hmmmm,Really not good.Pull it out and find a piece from the lower ring about a 1/4 way around totally missing.Cylinder wall not even damaged.Pull the Piston next to it and it has a 3" crack in about the same spot but no missing chunks.All the bearings were also toast.Worn down into the base metal.All this and this truck was Driven daily until I parked it in the field....it was even driven a couple times after it was parked to the store until I tire blew out and we needed the upper radiator hose for the race car.Talk about built Ford Tough.This truck was used,Abused,neglected,and flat out deliberatly tried to kill but it would not give up.
