Broken Bell housing fix sort of
Sergey
Washington
Hello,
a while back my truck bell housing cracked. Was asking about how to deal with it
Search for a replacement bell housing took so long, and even if found I won't be able to pay for the labor.
Also, while truck was sitting overwinter it was discovered that bell housing not just cracked, it crippled, bits fell on the ground, and even clutch fork jumped out. photo 1
With that in mind decided to use a hack instead - steel bar with a half-ball head bolt to replace the missing pivot point. Yes I realize it is not a proper repair. But implementing this fix did not require removing anything, and cost me only two 7/16" bolts to buy in hardware store. Remaining material was found in scrap metal pile. Mock up was made from wood, then a couple iterations using aluminum model. Final all steel part on photo 2.
Photo 3 shows it installed. Works well so far. Truck is now running, clutch fully functional. Did not take to highway yet, a bit worried how strong my part is.
Any concerns or some hidden dangers I need to know driving with this hacky fix ?
Thank you
Sergey
XOLATEM
Virginia... in the brambles
That is one nifty fix and I will copy that if mine busts out...(heaven forbid)...It should hold up just fine and now you have another clutch adjustment point.
Good Job..!
Rdnck84_03
Kansas
Only I would recommend is using a piece of angle iron or stitch welding strap onto that to make it into angle or channel to reduce the center flexing.
James
Black dawg
sw mt
That is pretty cool.
This is how I reinforce them when they are cracked or to avoid cracking. I just use a bolt to tighten up against the back of the stud in the bell. Have a few out there that I reinforced this way when cracks were noticed, 10+ years ago with no changes in the cracks.
ROCK HARVEY
Dayton OH
That’s a really clever fix! The only thing I could see causing problems is if the radius of the pivot ball doesn’t match the radius of the pivot fork. It could wear out pretty quickly. But then again, you can easily adjust the pivot ball to account for any wear, and it’s easier to grease now than it was stock. Well done!
