travelinman31
What would a 6.9 sound like without a glow plug screwed in one of the holes. I broke a stuck tip off and tried blowing it out with compression from the motor. Truck cranks and runs fine but has a definite tick on that cylinder. It looks like the tip is still stuck in the gp hole, but I'm not sticking my hand over hole with truck running to see if I can feel compression. Not sure if the tip is what seals the hole or if the tick is air coming around broke tip.
I figured when it blew out it would make a swooshing sound not a ticking sound, but I may be wrong. I haven't heard any loud pops like tip coming out or going down!! Not sure if that's good or bad at this point. Had an old mechanic tell me if it doesn't blow out fairly quickly after cranking truck and a short drive, just cut and old gp tip off and screw it in hole and roll on. That's about where I'm at at this point.
Thanks in advance.
Thanks in advance.
