Hard Shifting Problem Fixed
Now that this is fixed, I think there is a thing or two that could help someone else.
My original problem was that at 230,000 miles my truck was getting harder and harder to shift into 1st, 2nd and reverse. This was because I had no clutch reserve (the distance the clutch pedal travels between the floor and when the engine's power is first sent to the transmission. That was 0" for me.)
FIXES I TRIED:
-Play in the firewall: none
-I looked at the subject of this thread- the loosness at the top of the brake and clutch pedals. Ford sells some plastic parts that can remove this looseness. I decided that 1/16" of an inch wasn't enough to help with my problem. Knowing what I know now, I'll bet this would have helped me solve my problem.
-I had 7/16" travel in the clutch slave cylinder piston. 7/16" is the minimum spec. I put in a new clutch master and slave and the travel in the clutch slave cylinder piston didn't increase a bit, and hence my clutch reserve and shifting problems didn't change a bit.
-With the smaller jobs out of the way I opted for a new clutch kit and a change from the Dual Mass Flywheel to a Single Mass Flywheel. I didn't think was going to effect my problem, but I was running out of options. My Clutch Fork looked like it had lost 1/32 to 1/16 of metal where it contacts the throw out bearing, so I decided this couldn't be enough to effect my problem. Besides, getting a new one would have cost me another 1 hour trip to the auto parts store. I put the old fork back in. The new clutch and SMF had no effect on my hard shifting, but they had another huge effect...
-they shook my teeth out. After some persuading, the vendor who sold the clutch and SMF to me, shipped me another one at their expense, thinking the first one was out of balance. When I put this clutch and SMF in, I also put in a new Fork. On my test drive, I had about 1 1/2" of clutch reserve! That's the specked amount. Shifting was easy in the three troublesome gears!
From this, I think I have almost definitive evidence that the slightly worn fork was significant in making my gears shift more easily. I am in the process of putting together some photos and instructions for installing a new fork while the transmission is on the truck. I think these instructions could have saved me a lot of time. (In this process I replaced a near end of life DMF with a new SMF, replaced the clutch parts etc. so I did get a lot of good out of those repairs.) But I have to get those instructions together and will do so if here of a need for them from readers.
BigRedWeather
