brake pedal spongy
jimraelee
Gaston, OR
Yea I agree on that ABS valve.. found lots a air in there the first time I swapped out the master back in Nov when I bought the truck. I have learned something about fluid flow... I put the new master on back in Nov as said, and this time doing brake work I noticed how discolored the fluid in the master was... does this mean that the fluid in the system is traveling???? I wouldnt think the fluid would return to the master from a wheel cylinder. Or does the fluid just tarnish after a while of sunlight and engine heat???
m2rtin
