FoMoCo
Went to drive my parts truck around the farm today, and the brakes were not working as usual. The pedal would go to the floor and when I checked the Master it was empty. Got lucky and refilled the Master and the brakes are back but not as firm as they should be. The problem is I can not find the leak. I checked all the lines and components. It could be the slaves, but with that much fluid leaking you should see the fluid coming out of the drums.
This is just a truck that I bought for parts, but it runs so good I would like to keep it complete. Also, another question on a different subject. The oil in this parts truck does not turn black like my other 94 idi or my 05 VW TDI. It is so clear when you first change the oil it is hard to see on the dip stick. The guy I bought it from put a engine in it recently.
