Body swap questions
giezy
rockwood/on/Canada
Read some were that a mid 70' s truck has the same floor plans are trucks
Friend whats to trade some stuff for a long box ext cab 77 the same as my 94 would like to swap the body from the half ton to my frame
its not even much fab work, (dont consider this fab work)
the cab should be mounted with brackets that are riveted to the frame.
cut brackets off, relocate them, done.
the box mounts, are nothing more than a few drill holes away.
bumpers and steering are going to be the worst of it.
borgensen u-joints and double D steering shaft make that an easy task
The 80-up frames are too wide for the 70's bodies.
Alleycat
