Bmw 2.4L diesel performance help
ameristar1
The One Blue Thing
Steger, Illinois
If that Vixen was mine, this is what I would do.
Larger turbo to match the new power goal: lowers the egt's and allows for more fuel
Larger head unit for the Bosch VE pump
Larger piping for the turbo system
Larger but quiet exhaust system
Biggest air filter that will fit
FASS system
Water/methanol injection system
Get on Garrett Turbo's website and make the calculations for the turbo, then find an OEM or used turbo that will fit.
Change the coolant to Evans Zero Pressure coolant which will make the engine more thermally stable and increase reliability.
Synthetic oil mandatory
dieselgiant
Dieselgiant
Atmore, AL, USA
Any mods on the 5 speed manual and clutch. I have always been under the impression the the transaxle is a bit weak, but I dunno. Head studs the head is Aluminum.
ameristar1
The One Blue Thing
Steger, Illinois
Upgrade the clutch and pressure plate if you want, if you keep the power the level at around 200hp (flywheel) the trans should be fine. Studs should not be needed, ARP bolts should do fine, with a good multilayer gasket.
Deib
I have owned a couple Mark VII's I have one now, and a complete spare engine and tranny.
We were looking at dropping it in a Bronco II or something.
It is a just a standard VE pump, we have done some tuning. The lincoln was rolling smoke bad, all the time. A couple tweeks and the smoke it gone, more power, and fuel mileage is back up over 35.
I have put head gaskets in them, not a fun process. The engine was a marvel at the time it was created. There was nothing comparable to it, how quiet it was, and advanced electronics.
Getting ready to put a rear main seal in one soon. It will be fun.
thamojster
