Sparkandfire is rite on the heat helping the turbo, otherwise you'd want to cool the exhaust instead of heat wrapping it. BUT were not talking about turbos were talking about blowers.
1. duall charging is done with positive displacement blowers like an eaten or whipple, not with a centrifugal blower. A Centrifugal blower spools kinda like a turbo in that time is required for the turbine to create the pressure differential.
WrickM, I'm not so sure about this. It may be that it does to some extent, but it would'nt be as bad as a turbo's lag. A turbo just sort of free wheels along till the exhaust gases spin it enough to build boost. Where as if it were belt driven it could be rite on the edge of building boost at idle.
As far as a turbo being cheaper...I think that I could build something like this for under $400.
Stu
You're right, positive displacement blowers (roots type) don't have the lag that a turbo or centrifugal blower has.
I was debating some type of engine driven compressor system that kicks in when you hit the brakes, charges an air tank, then when you take off from a stop, a valve backfeeds the air into the intake of the engine to give you off the line boost. a "Diesel Hybrid" type thing...
the only problem with a blower is that it robs power from the crank. Obviously, it adds more power than it takes by virtue of the fact that it increases the air mass and preheats it. The logic behind the "turbo vs. blower" debate was that the turbo basically uses "waste" energy to operate.
I think you would be better off with a twin turbo setup, a small A/R turbo to get going off the line, then a larger one for high end boost.
Or figure out a way to run air foil bearings in your turbo...
