OldIron82
It's rude, it's crude, and I'm still in disbelief it worked, but it worked. I traced the new head gasket and drilled holes accordingly. I then drilled a center hole big enough to install the tip of the blow gun. I raised the piston to just below the suspect area and sprayed a good amount of Simple Green ( cleaner that is soapy ) on the top of the piston to cover the suspect area. Used a thick shop towel as a half arsed gasket, and tightened the bolts. I then gave it a shot of air. Well...the piston went down and another one went up and cracked the plate scaring the bejesus out of me. Ok, so I pulled the plate, added water and more soap to cover the suspect area and tried again. The constant pressure was blowing some liquid past the piston and it was running off the bottom of the crank. I held it for a good two minutes and then slowly lifted off to bleed the pressure, and removed the plate. Using a flashlight to shine into the water jacket............soapy suds running down the cylinder wall against the cam side. Not much, but a hole is a hole.
So that's it. No cheap and fast way out of this. Unless I find a running 6.9, I gotta go from the ground up. So be it. I reassembled the engine loosely and I'll be returning it to the salvage yard tomorrow and purchasing the 87 6.9 in the ambulance I spoke of months ago. This was a "if I find a good non ******* block I'll slap it together" gamble. Didn't cost me anything other than time. This was the engine I got the Roto-Master ( banks turbo ) off of early last summer. I knew it had a blown head gasket and water in the oil but I did hear it run so I figured it would be worth a chance. If it was good I would have installed the typ4 cam, studded it, installed my freshly redone heads with a valve job ( just the seats, guides in decent shape. ) and would have very happily pulled the tired 7.3 and installed her with the turbo.
Sent from my LG-H810 using Tapatalk
