biodiesel fuel line heater?
1989f2507.3idi
vernon,nj
will it work if i start my truck on the back tank?then mixed veggie with diesel+ hearter?
nooby how often does the water separator filter need to be changed and were is the fuel filter? frame?
Exekiel69
You should have the fuel filter on the engine pass side on the front it is a big bracket behind the alternator the filter is most times white and could have an aluminum bowl on the bottom (this You keep) or may just be a one piece filter in which case You just trow the hole thing away.
The fuel filter You can get on-line at filter1.com and the part #33617.
