it may have been a coincidence. what i do know is that about a week after the bio fuel incident the pump started leaking first where the throttle shaft enters the top housing. it was pouring out when it was running, would leave a 12" spot of fuel on the ground.
without removing the IP, i replaced those orings and the leak stopped for a while, then it started leaking from the underside of the pump where there are two screws each with a set of o-rings. the pump worked very well, it just leaked.
the newer materials in reman IP's may be compatible with bio fuel, this was the original IP from 1993, not much bio fuel back then when diesel was cheap. it may have been on its last leg and the bio fuel cleaned out the goo that was preventing a leak. i read that bio fuel is also a good solvent, and has sodium hydroxide (aka, crystal drano) in it from the refinement process.
anyhow, my new IP will never get to taste bio fuel.
