Sidewinded_idi
if live read my threads you know I've had a cooling issue since it's been 110+ lately. I acid boiled my radiator and cleaned the entire system and it works 100% better but on these really hot days it was still getting around 230-235, I have my heater core bypassed with the hoses simply connected together for a looped circuit.
My theory is what are the possibilities of this bypass since it uses 5/8 hose moving so much coolant it removes glow from the radiator? I ask because last night I installed a coolant filter setup in the heater circuit and the outlet on the Napa filter head is only around 1/4 inch so it must add resistance plus the filter media. But now I'm driving the truck with ac full blast same as day before and the truck is staying right at 200-210 and in the middle of the gauge instead of on the far right l,
My coolant is less than 500 miles old so I imagine it wasn't filtering contaminants my thought is the restriction is allowing the coolant to sit in the radiator properly now instead of flowing so much open the radiator is kind of like a bypass. Any thoughts I can't think of any other reason why it's cooling so much better with just adding rthe filter to new coolant
