OldIron82
Hello all. Been busy operating my own business, but down time coming soon and now I have a good amount of cash to get things done properly. I was dead set on a 6.9 forever but after thinking about what I'm going to be doing I was wondering if the 7.3 would be better.
I want to...1: Have a 6.9 bored just enough to true up the cylinders. 2: Order pistons of that bore size shaved to about a 18:1 compression ratio. 3: Ceramic coat pistons and use the full seal 2nd ring.
After this is done and reassembled, Go with a Bull or Omega Moose with R&D's stage 3 intercooler turbo kit.
Now financially speaking, would it not be better to just use a 7.3, sleeve all 8 cylinders to a stock piston size and then do the ceramic coating and piston shaving? Reason being I'll be able to use 7.3 IDIT pistons, stronger Powerstroke connecting rods ( if I'm not mistaken ) and thicker 1/2" ARP studs. I guess what I'm asking is would sleeving a 7.3 cost around the same as boring a 6.9? You have to bore them both anyway. I already have all the gaskets, studs, and two rebuilt heads for a 6.9. It would be a shame to have done that for nothing but if the 7.3 is going to yield a night and day difference of a more bombproof product I must consider it. Seeing as how I want to be decompressed I see no reason why the smaller 6.9 studs should fail me. They're still studs after all. I would greatly appreciate any insight. Thank you all.
OI82
OI82
