Hi everyone,
I don't own an IDI but my dad used to have a 93' 250 4x4 diesel that he used for his lawn care company and I am familiar with these trucks. I am going into the lawncare business too and will need a work truck. These IDI engines are so simple and reliable, getting one of these trucks seems almost like a no brainer (I wont be running any races with it either) but I had a few questions:
- I want an automatic - I'll be driving from neighborhood to neighborhood and will almost never see the freeway. It seems like I want a C6 - bulletproof right?
- There were quite a bit of small improvements from the 6.9 to 7.3 if I'm not mistaken (bearings, fuel system, glow plugs, head bolts, etc). So it also seems like I want a 7.3
1) From my research, the C6 was in these trucks untill '88 and the 7.3 started in 88'. I may be wrong but is the '88 year truck the only year with the 7.3 and C6 combo?
2) Are there significant problems with the 6.9 engine? Do the things that they changed going to the 7.3 fail early? Are parts for the 6.9 hard to find?
3) My dads 4x4 7.3 had front tires that looked like this / \ from the front. It also had death wobble at 70 mph unless the tires were warm and three shops told us it couldn't be aligned. The suspension was not up to the task of dealing with the 7.3 (130,*** miles, never with a snow plow or anything). Is this a problem with the 2x4? This truck will only be driven in the summer and the simplicity of a 2x4 seems way better.
4) Final question. I'm interested in your guys' opinions on this question: Is a 2x4 IDI C6 Ford the best work truck? Is it as simple and reliable as I figure it is? Are parts cheap and available because it uses a medium duty truck engine in a chassis that was used for 16 years? Would I loose any of these benifits with a 6.9 C6 combo? Obviously a 2011 6.7 F450 4x4 would be a better work truck but considering budget, if you were looking for a diesel 2x4 automatic truck, would you be looking at 7.3 C6 trucks or should I be looking at something else (My plan is to get one over the winter and fix it up for the following summer - bearings, tires, brakes, paint, etc)?
Long post, Jeez, Thanks for any input,
Matt
Matt
