GREASE FIRE
the F250 7.3 i just bought did have sca put in it but the previous owner (for the last 10K miles) said he just used tap water instead of distilled water because that is just how he operates - he spent over $350 for a new radiator, bought new upper & lower hoses plus 4 gallons of coolant plus sca but then decided to skimp on $3.50 worth of distilled water....
so as i understand it the sca didn't do much good, so now i am going to do the job right.
Now on my 6.2 i had the radiator off this summer and the lower radiator hose but this did not drain the block of coolant. what about on a 7.3? will most of it come out when you remove the lower hose or is there another way to do it?
thanks,
paul
thanks,
paul
