Best style N/A intake...
Status
Not open for further replies.
Optikalillushun
Coal Region, Pa
I've done an extensive search on this subject but everything was scattered. id like to have all the info compiled into one thread.
i want to make my own intake system. i have seen styles that route to the radiator support, cowl area, passenger side behind the battery and ghost tube. my question...what are the Pro/Cons of each? and which is best for a diff. application?
i hope this isnt to broad of a topic or im asking to much. ;Sweet
Optikalillushun
Coal Region, Pa
Anyone?
i seen Hypermax offers a cowl induction intake, but wouldnt that let in water when it rains?
What about running a larger diameter ducting to the radiator support like the 300/460 EFI trucks?
what about running it on the passenger side behind the battery?
what about the "ghost" tube" or TBI style hat and intake (open element filter)?
Headerpower
Powell River, B.C.
Ram air deflector from behind the grill up to a big fiberglass scoop- only cut plastic. More pics in my gallery on the FTE pre power stroke forum KJLYPW.
turbo69
Innocent Bystander
Garland, TX
Ghost Tube as requested...
...It's actually an open element filter system by air raid that fits 2001 dodge p/u with 318.
Optikalillushun
Coal Region, Pa
Turbo69, whats the block off plate installed on the front of the intake (or rear) and ip adaptor in ur pic gallery?
notice much improvement with the "ghost tube"?
Petri317
Napa, CA
Was the black piece that screws onto the manifold fabricated by you, or part of the Airaid kit?
Cheaper Jeeper
Kent, WA
Added a second "snorkle" to the stock air breather assembly
Installed scoops in both the turn signal openings
Plumbed the scoops into the wheelwells & up through the fender liners into the engine bay
And attached the plumbing to the dual snorkles using stock intake tubes
VIOLA' dual ram-air....
Dunno why I can't get the pictures to display - only links. Maybe KJLYPW can PM me the secret.... ;)
Links are dead for me to. To ensure the longevitiy of the tech article, it would be best to include the pictures as attachements. Just remember not to delete them from your account later!
payableondeath6
Impressively Ugly
Marion, OH
Excuse the crappy cell phone pic, it was the only thing I had on me while I was loading hay last night.
Optikalillushun
Coal Region, Pa
I was looking at my cowl area by the wiper motor and such, i dont understand how hypermax's kit works. i dont have any room anywhere on the cowl to locate the air intake kit...my vacuum booster is HUGE (compared to my F-150s).
i like the intake Zigg posted with the stove pipe...i may go with that style.
Wanderer-rrorc
newark,OH
need to get a pic on the inside...stock hose zip tied so the air flows right into it on the pass side...driver side is for engine air/engine comparment vent.
inside
tractorman86
Buckeye, AZ
i've got the same setup as payableondeath6 w/a K&N and love it. if i had an 86 style i would have to replicate cheeper jeeper's setup.
F350farmboy
The Hornet
N.E Ohio
I followed cheaper's advise and did the dual air intake....along with his help with the ZF swap (holding up great! I can have a conversation at 75 mph!! thanks again)
fastass350
SStock8569
Washougal, Wa
So, what was the verdict, on the ghost tube setup, the bowl that bolts to the intake, where is that found at? Who makes it, and who carries it?
Thanks.
Chris
Status
